									Reloj del yaesu ftdx1200 no conserva la hora - Técnico				            </title>
            <link>https://www.ure.es/foros/tecnico/reloj-del-yaesu-ftdx1200-no-conserva-la-hora/</link>
            <lastBuildDate>Tue, 11 Aug 2026 01:55:27 +0000</lastBuildDate>
                        <title>RE: Reloj del yaesu ftdx1200 no conserva la hora</title>
                        <link>https://www.ure.es/foros/tecnico/reloj-del-yaesu-ftdx1200-no-conserva-la-hora/#post-394405</link>
                        <pubDate>Tue, 04 Jun 2024 16:34:06 +0000</pubDate>
                        <description><![CDATA[€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€]]></description>
                        <content:encoded><![CDATA[
<p>Para saber si el problema es uno u otro, te recomendamos encarecidamente que nos envíes tu radio para que podamos hacer un diagnóstico más preciso y entender cuál es el problema.</p>
                        <guid isPermaLink="true">https://www.ure.es/foros/tecnico/reloj-del-yaesu-ftdx1200-no-conserva-la-hora/#post-394405</guid>
                        <link>https://www.ure.es/foros/tecnico/reloj-del-yaesu-ftdx1200-no-conserva-la-hora/#post-394050</link>
                        <pubDate>Thu, 23 May 2024 17:49:56 +0000</pubDate>
                        <description><![CDATA[hola de nuevo, me han dicho esto en el servicio tecnico en italia:
Dear Customer,
thank you for your email.
Looking at your problem and comparing it with our workshop, we advise you that ...]]></description>
                        <content:encoded><![CDATA[<p>hola de nuevo, me han dicho esto en el servicio tecnico en italia:</p>
<p>Dear Customer,</p>
<p>thank you for your email.</p>
<p>Looking at your problem and comparing it with our workshop, we advise you that if the radio has been switched off for a long time and/or disconnected from the power supply, it may be worth trying leaving the radio switched on for a whole day to let the battery recharge.</p>
<p>If this does not work, there may be two problems.</p>
<ol>
<li>It could be that the battery charging circuit is not working.</li>
<li>Or the problem is the battery itself which is inside the CNTL-ASSY.</li>
</ol>
<p>To find out if the problem is one or the other, we strongly encourage you to send us your radio so that we can make a more accurate diagnosis and understand what the problem is.</p>
<p>In order to proceed with the repair, we kindly ask you to fill in the form you can find in this link (<a href="https://www.csyeson.it/it/content/26-invia-una-riparazione">https://www.csyeson.it/it/content/26-invia-una-riparazione</a>) and then proceed with the shipment of the radio.</p>
<p>Thank you</p>
<p>.</p>
<p>.</p>
<p>.</p>
<p>.</p>
<p>que traducido por google:</p>
<p>Estimado cliente,<br /><br />gracias por su correo electrónico.<br /><br />Viendo tu problema y comparándolo con nuestro taller, te aconsejamos que si la radio ha estado mucho tiempo apagada y/o desconectada de la corriente, puede que te merezca la pena intentar dejar la radio encendida durante un día entero para Deje que la batería se recargue.<br /><br />Si esto no funciona, puede haber dos problemas. <br /><br />1. Podría ser que el circuito de carga de la batería no esté funcionando.<br />2. O el problema es la batería misma que está dentro del CNTL-ASSY.<br /><br />Para saber si el problema es uno u otro, te recomendamos encarecidamente que nos envíes tu radio para que podamos hacer un diagnóstico más preciso y entender cuál es el problema.<br /><br />Para proceder con la reparación, le rogamos que rellene el formulario que encontrará en este enlace (https://www.csyeson.it/it/content/26-invia-una-riparazione) y luego proceda con el envío de la radio. <br /><br />Gracias</p>
						                            <category domain="https://www.ure.es/foros/tecnico/">Técnico</category>                        <dc:creator>EA7GGU</dc:creator>
                        <guid isPermaLink="true">https://www.ure.es/foros/tecnico/reloj-del-yaesu-ftdx1200-no-conserva-la-hora/#post-394050</guid>
                        <link>https://www.ure.es/foros/tecnico/reloj-del-yaesu-ftdx1200-no-conserva-la-hora/#post-393724</link>
                        <pubDate>Thu, 09 May 2024 19:06:29 +0000</pubDate>
                        <description><![CDATA[me has convencido¡¡¡¡¡
EL ROLEX¡¡¡¡¡¡¡]]></description>
                        <content:encoded><![CDATA[<p>me has convencido¡¡¡¡¡</p>
<p>EL ROLEX¡¡¡¡¡¡¡</p>]]></content:encoded>
                        <guid isPermaLink="true">https://www.ure.es/foros/tecnico/reloj-del-yaesu-ftdx1200-no-conserva-la-hora/#post-393724</guid>
                        <link>https://www.ure.es/foros/tecnico/reloj-del-yaesu-ftdx1200-no-conserva-la-hora/#post-393720</link>
                        <pubDate>Thu, 09 May 2024 14:52:06 +0000</pubDate>
                        <description><![CDATA[Veo que es una pila pequeña, recargable, y encima soldada,,,, hay que tener mucho cuidado con el soldador con calor suelen reventar,,, asi que,, mejor ni lo toques y pudes ver la hora desde ...]]></description>
                        <content:encoded><![CDATA[<p>Veo que es una pila pequeña, recargable, y encima soldada,,,, hay que tener mucho cuidado con el soldador con calor suelen reventar,,, asi que,, mejor ni lo toques y pudes ver la hora desde ordenador o de paso te compras un rolex.-</p>
						                            <category domain="https://www.ure.es/foros/tecnico/">Técnico</category>                        <dc:creator>EA2EGZ</dc:creator>
                        <guid isPermaLink="true">https://www.ure.es/foros/tecnico/reloj-del-yaesu-ftdx1200-no-conserva-la-hora/#post-393720</guid>
                        <link>https://www.ure.es/foros/tecnico/reloj-del-yaesu-ftdx1200-no-conserva-la-hora/#post-393718</link>
                        <pubDate>Thu, 09 May 2024 13:22:01 +0000</pubDate>
                        <description><![CDATA[muchas gracias¡¡¡
muy ilustrativo¡¡¡
el problema es que no tengo el soldador especial para este tipo de operaciones, tengo el típico para soldar cosas menos delicadas y no me atrevo a usar...]]></description>
                        <content:encoded><![CDATA[<p>muchas gracias¡¡¡</p>
<p>muy ilustrativo¡¡¡</p>
<p>el problema es que no tengo el soldador especial para este tipo de operaciones, tengo el típico para soldar cosas menos delicadas y no me atrevo a usarlo aquí...</p>
<p>73´s</p>]]></content:encoded>
                        <guid isPermaLink="true">https://www.ure.es/foros/tecnico/reloj-del-yaesu-ftdx1200-no-conserva-la-hora/#post-393718</guid>
                        <link>https://www.ure.es/foros/tecnico/reloj-del-yaesu-ftdx1200-no-conserva-la-hora/#post-393707</link>
                        <pubDate>Thu, 09 May 2024 07:09:53 +0000</pubDate>
                        <description><![CDATA[Hola
Mira este mensaje en Goups.io que detalla el problema de tu equipo
Suerte]]></description>
<p>Mira este mensaje en Goups.io que detalla el problema de tu equipo</p>
<p>https://www.google.com/url?sa=t&amp;source=web&amp;rct=j&amp;opi=89978449&amp;url=https://groups.io/g/FTdx-1200/topic/time_settings_not_holding/71110309%3Fp%3D&amp;ved=2ahUKEwiGh_mqgYCGAxWE8AIHHQSxD0QQFnoECBUQAQ&amp;usg=AOvVaw1sFta3fMkCp_TAsuVU3vPl</p>
<p>Suerte </p>]]></content:encoded>
                        <guid isPermaLink="true">https://www.ure.es/foros/tecnico/reloj-del-yaesu-ftdx1200-no-conserva-la-hora/#post-393707</guid>
                        <link>https://www.ure.es/foros/tecnico/reloj-del-yaesu-ftdx1200-no-conserva-la-hora/#post-393702</link>
                        <pubDate>Thu, 09 May 2024 02:56:28 +0000</pubDate>
                        <description><![CDATA[hola, contacté con el servicio técnico de yaesu en italia les dije el problema que tengo y me dieron esta respuesta:
La batería está disponible, precio y código a continuación, IVA incluido...]]></description>
                        <content:encoded><![CDATA[<p>hola, contacté con el servicio técnico de yaesu en italia (https://www.csyeson.it/es/) les dije el problema que tengo y me dieron esta respuesta:</p>
<p>La batería está disponible, precio y código a continuación, IVA incluido:</p>
<ul>
<li>8,00€ Q9000895 LI-ION BATTERY ML614R-TT31 VX-8E, FT-991</li>
<li>El envío por mensajero express se calculará en función de la dirección de entrega.</li>
</ul>
<p>he seguido indagando y la pila se encuenta en la parte inferior del equipo</p>
<p>73´s</p>
                        <guid isPermaLink="true">https://www.ure.es/foros/tecnico/reloj-del-yaesu-ftdx1200-no-conserva-la-hora/#post-393702</guid>
                        <link>https://www.ure.es/foros/tecnico/reloj-del-yaesu-ftdx1200-no-conserva-la-hora/#post-393637</link>
                        <pubDate>Mon, 06 May 2024 15:31:23 +0000</pubDate>
                        <description><![CDATA[hola¡¡¡, pues eso mismo pensé yo, en dejar algún tiempo la fuente encendida para probar, pero realmente no merece la pena...
como es sólo la hora (y bien pequeña¡¡¡¡) pues creo que no merec...]]></description>
                        <content:encoded><![CDATA[<p>hola¡¡¡, pues eso mismo pensé yo, en dejar algún tiempo la fuente encendida para probar, pero realmente no merece la pena...</p>
<p>como es sólo la hora (y bien pequeña¡¡¡¡) pues creo que no merece la pena calentarse mucho¡¡¡</p>
<p>para eso buena idea lo del reloj externo</p>
                        <guid isPermaLink="true">https://www.ure.es/foros/tecnico/reloj-del-yaesu-ftdx1200-no-conserva-la-hora/#post-393637</guid>
                        <link>https://www.ure.es/foros/tecnico/reloj-del-yaesu-ftdx1200-no-conserva-la-hora/#post-393631</link>
                        <pubDate>Mon, 06 May 2024 13:16:52 +0000</pubDate>
                        <description><![CDATA[Por más que he buscado (puede que alguien haya encontrado algo más), no veo en ningún sitio que hablen de una batería como tal, por lo que supongo que la fecha y hora deben de quedar guardad...]]></description>
                        <content:encoded><![CDATA[<p>Por más que he buscado (puede que alguien haya encontrado algo más), no veo en ningún sitio que hablen de una batería como tal, por lo que supongo que la fecha y hora deben de quedar guardadas mediante la carga de un condensador.</p>
<p>Si enciendo el equipo a menudo no se pierden, pero este sólo lo enciendo esporádicamente.</p>
<p>Por suerte no se pierden las memorias ni ningún parámetro del menú, ni siquiera el indicativo, que también se introduce en el mismo menú de configuración, sólo fecha y hora.</p>
<p>Curiosamente parece que una vez puesto en hora, si mantienes la alimentación aunque no esté encendido el equipo, se mantienen, pero tampoco voy a dejar encendida la fuente de forma indefinida, ya que realmente no me hace falta mantener esos datos, pues justo encima tengo un reloj con la hora UTC y este equipo no tiene APRS para registrar cuándo se han recibido las tramas, algo que sí me interesa saber.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://www.ure.es/foros/tecnico/reloj-del-yaesu-ftdx1200-no-conserva-la-hora/#post-393631</guid>
                        <link>https://www.ure.es/foros/tecnico/reloj-del-yaesu-ftdx1200-no-conserva-la-hora/#post-393625</link>
                        <pubDate>Mon, 06 May 2024 08:05:10 +0000</pubDate>
                        <description><![CDATA[hola¡¡, efectivamente eso es exactamente  lo que estoy viendo que le sucede¡¡¡]]></description>
                        <content:encoded><![CDATA[<p>hola¡¡, efectivamente eso es exactamente  lo que estoy viendo que le sucede¡¡¡</p>]]></content:encoded>
                        <guid isPermaLink="true">https://www.ure.es/foros/tecnico/reloj-del-yaesu-ftdx1200-no-conserva-la-hora/#post-393625</guid>
