									Nuevo Analizador de Antenas - Técnico				            </title>
            <link>https://www.ure.es/foros/tecnico/nuevo-analizador-de-antenas/</link>
            <lastBuildDate>Mon, 14 Sep 2026 06:10:50 +0000</lastBuildDate>
                        <title>Re:Re: Nuevo Analizador de Antenas</title>
                        <link>https://www.ure.es/foros/tecnico/nuevo-analizador-de-antenas/#post-217412</link>
                        <pubDate>Mon, 11 Mar 2013 07:50:18 +0000</pubDate>
                        <description><![CDATA[Ya tenemos precios y alguna promoción:
Hello Luis
Thank you for your interest in my webside my ofert
Info analyzers MAX6
PRICE  :
Normal price only Info analyzers MAX6
MAX6-180MHz  -  35...]]></description>
                        <content:encoded><![CDATA[Ya tenemos precios y alguna promoción:<br />
Hello Luis<br />
Thank you for your interest in my webside my ofert<br />
Info analyzers MAX6<br />
PRICE  :<br />
Normal price only Info analyzers MAX6<br />
MAX6-180MHz  -  350 €<br />
MAX6-500MHz  -  450 €<br />
Price promotion<br />
HEXBEAM + MAX6<br />
MAX6-180MHz  -  330  €<br />
MAX6-500MHz  -  425 €<br />
HEXBEAM MARK II + balun (only set) = 435 €  + 30 €  = only 465 €<br />
shipment to Spain now - only 20€<br />
Frequency coverage - depend on model  (and price)<br />
1-180 MHz    or  1-500MHz<br />
measurement resolution<br />
- in PC mode  1Hz<br />
- in LCD mode  1kHz<br />
Build in Li-Ion battery<br />
- MAX6-180 - 4 hour continuous work<br />
- MAX6-500 - 1,5 hour continuous work (will be expanded by firmware upgrade)<br />
AUTO POWER OFF<br />
Can be charged any time wee need  from 12...14V DC stabilized supplu  ( from Car too)<br />
Small pocket size<br />
LCD 128x64 with regulated backlit ond good visibility in direct sunlight<br />
Remote control via  IR remote control<br />
DDS Generator with 10 dBm  to 20dBm output<br />
2 Ports allow Transmission Measurements e.g. filters<br />
additional two RF channel for duplexer and triplexer measurement (ACCessory socket)<br />
USB1.1 and USB2 compatibility<br />
RS232 TTL - ACCessory  socket Bluetooth - and remote Android or PC application<br />
Very Fast Scan (typical 0.6 sec for 500 points)<br />
High Reflection Dynamic eturn Loss range -  40dB to 35dB (VSWR 1.06:1  up to  1,02:1 )<br />
Wide Dynamic Range in Transmission  mode up to 65dB<br />
Filter measurement from both side in this same time  SWR Z and Transmission<br />
Measures VSWR, RL, Rs, Z +/-jx, Phase, Cable lenght, R/L/C<br />
Typical impedance 50 ohm<br />
Cable impedance (transmission line) measurement<br />
Very high impedance measurement up to 50000 kohm (for example choke balun impedance)<br />
Finds Minimum VSWR automatically in PC  and LCD moce<br />
Save data to SD CARD in three formats ZPLOT S2P TXT<br />
UPGRADE  Self Programming for future firmware - using just SD card<br />
Software compatible with Windows and Linux  and MAC<br />
If you have any questions, write]]></content:encoded>
						                            <category domain="https://www.ure.es/foros/tecnico/">Técnico</category>                        <dc:creator>EA4NR</dc:creator>
                        <guid isPermaLink="true">https://www.ure.es/foros/tecnico/nuevo-analizador-de-antenas/#post-217412</guid>
                        <link>https://www.ure.es/foros/tecnico/nuevo-analizador-de-antenas/#post-206868</link>
                        <pubDate>Fri, 08 Mar 2013 08:35:38 +0000</pubDate>
                        <description><![CDATA[ese es el precio de la antena en promocion... para el medidor te dan el precio por email
MAX6 antena analyser - price e-mail]]></description>
                        <content:encoded><![CDATA[ese es el precio de la antena en promocion... para el medidor te dan el precio por email<br />
MAX6 antena analyser - price e-mail]]></content:encoded>
						                            <category domain="https://www.ure.es/foros/tecnico/">Técnico</category>                        <dc:creator>EA7BJ</dc:creator>
                        <guid isPermaLink="true">https://www.ure.es/foros/tecnico/nuevo-analizador-de-antenas/#post-206868</guid>
                        <link>https://www.ure.es/foros/tecnico/nuevo-analizador-de-antenas/#post-217355</link>
                        <pubDate>Fri, 08 Mar 2013 06:21:55 +0000</pubDate>
                        <description><![CDATA[Special Price : 435  € !
no se si sera este precio...es lo lo que pone en la pagina web.... Yo personalmente lo mirare porque necesito uno urgentemente!
Saludos desde Suiza!]]></description>
                        <content:encoded><![CDATA[Special Price : 435  € !<br />
no se si sera este precio...es lo lo que pone en la pagina web.... Yo personalmente lo mirare porque necesito uno urgentemente!<br />
Saludos desde Suiza!]]></content:encoded>
						                            <category domain="https://www.ure.es/foros/tecnico/">Técnico</category>                        <dc:creator>EA1IIW</dc:creator>
                        <guid isPermaLink="true">https://www.ure.es/foros/tecnico/nuevo-analizador-de-antenas/#post-217355</guid>
                        <link>https://www.ure.es/foros/tecnico/nuevo-analizador-de-antenas/#post-215103</link>
                        <pubDate>Thu, 07 Mar 2013 11:56:11 +0000</pubDate>
                        <description><![CDATA[Tiene buena pinta ¿Alguien que lo tenga podría aportar sus impresiones?
Saludos]]></description>
                        <content:encoded><![CDATA[Tiene buena pinta ¿Alguien que lo tenga podría aportar sus impresiones?<br />
Saludos]]></content:encoded>
                        <guid isPermaLink="true">https://www.ure.es/foros/tecnico/nuevo-analizador-de-antenas/#post-215103</guid>
                        <link>https://www.ure.es/foros/tecnico/nuevo-analizador-de-antenas/#post-207001</link>
                        <pubDate>Sat, 09 Feb 2013 20:14:02 +0000</pubDate>
                        <description><![CDATA[HOLA
Alguien en EA por casualidad ya lo tiene?
JORGE
EA8TL]]></description>
                        <content:encoded><![CDATA[HOLA<br />
Alguien en EA por casualidad ya lo tiene?<br />
JORGE<br />
EA8TL]]></content:encoded>
						                            <category domain="https://www.ure.es/foros/tecnico/">Técnico</category>                        <dc:creator>EA8TL</dc:creator>
                        <guid isPermaLink="true">https://www.ure.es/foros/tecnico/nuevo-analizador-de-antenas/#post-207001</guid>
                        <link>https://www.ure.es/foros/tecnico/nuevo-analizador-de-antenas/#post-206874</link>
                        <pubDate>Sat, 10 Nov 2012 20:06:54 +0000</pubDate>
                        <description><![CDATA[Tiene muy buena pinta, a ver si nos sorprende el precio...
                        <content:encoded><![CDATA[Tiene muy buena pinta, a ver si nos sorprende el precio...<br />
73]]></content:encoded>
						                            <category domain="https://www.ure.es/foros/tecnico/">Técnico</category>                        <dc:creator>EC7ZK</dc:creator>
                        <guid isPermaLink="true">https://www.ure.es/foros/tecnico/nuevo-analizador-de-antenas/#post-206874</guid>
                        <link>https://www.ure.es/foros/tecnico/nuevo-analizador-de-antenas/#post-206867</link>
                        <pubDate>Thu, 08 Nov 2012 19:51:15 +0000</pubDate>
                        <description><![CDATA[Waldi todavía no ha informado sobre el precio, conociéndole por sus antenas que están hechas con buena calidad y buen precio(doy fe de ello), espero que con éste analizador haga lo mismo.......]]></description>
                        <content:encoded><![CDATA[Waldi todavía no ha informado sobre el precio, conociéndole por sus antenas que están hechas con buena calidad y buen precio(doy fe de ello), espero que con éste analizador haga lo mismo....si es así, aquí ya hay un interesado....<br />
73 David.EA1GGJ]]></content:encoded>
						                            <category domain="https://www.ure.es/foros/tecnico/">Técnico</category>                        <dc:creator>EA1WH</dc:creator>
                        <guid isPermaLink="true">https://www.ure.es/foros/tecnico/nuevo-analizador-de-antenas/#post-206867</guid>
                        <title>Nuevo Analizador de Antenas</title>
                        <link>https://www.ure.es/foros/tecnico/nuevo-analizador-de-antenas/#post-22151</link>
                        <pubDate>Thu, 08 Nov 2012 18:44:44 +0000</pubDate>
                        <description><![CDATA[https://www.ure.es/wp-content/uploads/wpforo/default_attachments/media/kunena/attachments/3724/DownloadedFile.jpeg]]></description>
                        <content:encoded><![CDATA[http://sp7idx-hexbeam.eu/max6-antenna-analyzers/<br />
https://www.ure.es/wp-content/uploads/wpforo/default_attachments/media/kunena/attachments/3724/DownloadedFile.jpeg]]></content:encoded>
						                            <category domain="https://www.ure.es/foros/tecnico/">Técnico</category>                        <dc:creator>EA5AWC</dc:creator>
                        <guid isPermaLink="true">https://www.ure.es/foros/tecnico/nuevo-analizador-de-antenas/#post-22151</guid>
