									ICOM 7800 PROBLEMAS - Técnico				            </title>
            <link>https://www.ure.es/foros/tecnico/icom-7800-problemas-2/</link>
            <lastBuildDate>Thu, 15 Oct 2026 04:30:08 +0000</lastBuildDate>
                        <title>Re:ICOM 7800 PROBLEMAS</title>
                        <link>https://www.ure.es/foros/tecnico/icom-7800-problemas-2/#post-317781</link>
                        <pubDate>Fri, 15 Dec 2017 06:04:02 +0000</pubDate>
                        <description><![CDATA[Ya lo encontré, le llaman IC-7800 Plus
Mejoras:
Spectrum Waterfall Display: Review RF and AF characteristics on the IC-7800’s impressive 7-inch color LCD. Includes a wide screen setting.
...]]></description>
                        <content:encoded><![CDATA[Ya lo encontré, le llaman <b>IC-7800 Plus</b><br />
Mejoras:<br />
Spectrum Waterfall Display: Review RF and AF characteristics on the IC-7800’s impressive 7-inch color LCD. Includes a wide screen setting.<br />
PC Mouse Operation: Connect a mouse via USB to select operating frequency and control the spectrum scope.<br />
Audio Scope Function: Review the FFT scope with waterfall and oscilloscope. In CW mode, observe mic compressor level and other attributes.<br />
Direct Remote Control Operation: Connect directly to an IP network using Icom’s optional RS-BA1 software and the IC-7800’s internal base station function. (A user operation PC is still required; a base station PC is not.)<br />
Digital Voice Recorder: Automatically capture incoming/outgoing calls onto an external memory card or flash drive.<br />
<a href="https://www.youtube.com/watch?v=q2OUFX7EPZ8" class="bbcode_url">https://www.youtube.com/watch?v=q2OUFX7EPZ8</a><br />
73, Máximo]]></content:encoded>
                        <guid isPermaLink="true">https://www.ure.es/foros/tecnico/icom-7800-problemas-2/#post-317781</guid>
                        <link>https://www.ure.es/foros/tecnico/icom-7800-problemas-2/#post-317780</link>
                        <pubDate>Fri, 15 Dec 2017 06:00:05 +0000</pubDate>
¿Probaste a hacerle un reseteo?
No conozco como, pero seguro tiene una manera de hacer un reseteo general, para que quede como cuando viene de fabrica.
Además, a veces también soluc...]]></description>
¿Probaste a hacerle un reseteo?<br />
No conozco como, pero seguro tiene una manera de hacer un reseteo general, para que quede como cuando viene de fabrica.<br />
Además, a veces también soluciona cosas actualizar el firmware.<br />
¿Lo tienes con la última versión?<br />
No se si tu modelo es el MKI, o el MKII.<br />
Y para rematar, recientemente Icom a sacado una actualización más. No recuerdo exactamente pero creo que era un nuevo oscilador o algo así.<br />
                        <guid isPermaLink="true">https://www.ure.es/foros/tecnico/icom-7800-problemas-2/#post-317780</guid>
                        <link>https://www.ure.es/foros/tecnico/icom-7800-problemas-2/#post-317549</link>
                        <pubDate>Fri, 15 Dec 2017 05:42:50 +0000</pubDate>
                        <description><![CDATA[Gracias por la información, cambiada la pila y continua haciendo lo mismo, y lo mas sorprendente, lo consulto con Icom y la única información es que la mande,  portes de ida y vuelta mas abr...]]></description>
                        <content:encoded><![CDATA[Gracias por la información, cambiada la pila y continua haciendo lo mismo, y lo mas sorprendente, lo consulto con Icom y la única información es que la mande,  portes de ida y vuelta mas abrirla 300 400 Euros seguro que me cuesta, haber si alguien que la tenga le hubiese ocurrido lo mismo.<br />
Gracias]]></content:encoded>
						                            <category domain="https://www.ure.es/foros/tecnico/">Técnico</category>                        <dc:creator>EA7ST</dc:creator>
                        <guid isPermaLink="true">https://www.ure.es/foros/tecnico/icom-7800-problemas-2/#post-317549</guid>
                        <link>https://www.ure.es/foros/tecnico/icom-7800-problemas-2/#post-317551</link>
                        <pubDate>Tue, 12 Dec 2017 09:48:21 +0000</pubDate>
                        <description><![CDATA[Esa es solo para el reloj. Bien clarito lo pone.
Seguramente tenga otra interna, o puede que no, porque ya siendo moderno utilizara una flash ram, que no necesita alimentación.
73,
Jose]]></description>
                        <content:encoded><![CDATA[Esa es solo para el reloj. Bien clarito lo pone.<br />
Seguramente tenga otra interna, o puede que no, porque ya siendo moderno utilizara una flash ram, que no necesita alimentación.<br />
73,<br />
Jose]]></content:encoded>
                        <guid isPermaLink="true">https://www.ure.es/foros/tecnico/icom-7800-problemas-2/#post-317551</guid>
                        <link>https://www.ure.es/foros/tecnico/icom-7800-problemas-2/#post-317548</link>
                        <pubDate>Mon, 11 Dec 2017 08:10:55 +0000</pubDate>
                        <description><![CDATA[Hola el síntoma que explicas normalmente es la bateria,
Solo tienes que reemplazarla.
Francesc]]></description>
                        <content:encoded><![CDATA[Hola el síntoma que explicas normalmente es la bateria,<br />
Solo tienes que reemplazarla.<br />
Un saludo<br />
Francesc]]></content:encoded>
						                            <category domain="https://www.ure.es/foros/tecnico/">Técnico</category>                        <dc:creator>EA3GIL</dc:creator>
                        <guid isPermaLink="true">https://www.ure.es/foros/tecnico/icom-7800-problemas-2/#post-317548</guid>
                        <link>https://www.ure.es/foros/tecnico/icom-7800-problemas-2/#post-317547</link>
                        <pubDate>Mon, 11 Dec 2017 05:40:37 +0000</pubDate>
                        <description><![CDATA[La batería interna de la memoria agotada probablemente, sera interna, habrá que abrir el aparato. De todos modos no conzco dicho equipo.]]></description>
                        <content:encoded><![CDATA[La batería interna de la memoria agotada probablemente, sera interna, habrá que abrir el aparato. De todos modos no conzco dicho equipo.]]></content:encoded>
						                            <category domain="https://www.ure.es/foros/tecnico/">Técnico</category>                        <dc:creator>EA2EKF</dc:creator>
                        <guid isPermaLink="true">https://www.ure.es/foros/tecnico/icom-7800-problemas-2/#post-317547</guid>
